Corolla 98 Linea Terra Window Crank
M.J
I have a 1998 corolla linea terra saloon and I am trying to take off the front door panel as the speaker on the drivers side is not working and I want to see if it's blown or if there are loose wires etc, but for the life of me I cant get the window crank off the door and I dont want to force it too hard in case I break the handle, does anyone know how to get it off.
Put the Crank up than put a small screwdriver BEHIND the Cranck and the the Doorpanel ther you wil see a little half round spring that you have to push downwards when thats down youre crank is lose
Put the screwdriver between the crank and the doorpanel and LOOK BETWEEN those things then you now what i mean BUT becareful when you push to hard the spring wil JUMP away !!!!
