Gt4 Shocks
Overload
Hello,
Picture of part needing identifying
Cutting a long story short, does any one know if the bit highlighted in green is a standard part on the ST205. I beginning to think that it isn't as you can see red paint.
Reason why I am asking is because I believe that that bit is very slightly bent (where the rust/paint has flaked off) and thus does not drive in a straight line (this is after being to toyota for alignment).
They are GAB shocks (bought with the car) and having looked over the net have not found anything like that bit highlighted. So if I cannot get a replacement part, I'll be looking at new shocks.
Would it also be possible if any owners could post a picture of thier st205 shocks.
The shock in the picture is on the front passenger side.
Thank you all for your help.
look in the how to section - suspension , for pics.
http://www.gtfours.co.uk/
looks normal to me , part of superstrut suspension set up.
front shocker standard http://www.fensport.co.uk/parts.htm 154 quid.
or try here http://www.tcbparts.co.uk/ these guys sell 2nd hand gear alot cheaper
