Losing Screws
SilverT4
I have now managed to lose all four of the small screws that fix the 'hooks' to the end of the luggage cover.
After a quick rummage in the bottom of the boot, I managed to find two of them and have refixed them, but they don't seem very secure. Don't suppose it will be long before they fall out again.
Anyone else had this problem?
It's happened to me twice now. Thankfully I found them both times. I think I'll go check if they're working loose again! :D
I don't understand what screws you lot are going on about. The luggage cover is the Slidable cover right?
On the sliding cover over the boot space, there are bits of plastic that hook into supports at the side of the car at the rear. They keep the cover pulled back.
Those bits of plastic on each side each have two small black screw on the underside.
Mine haven't fallen out for some time now.
Yes, on the sliding cover there are two plastic fittings that hook onto the sides of the boot and prevent the cover rolling back into its holder. Each fitting is held to the cover by two small screws.
