Coolant Drain Plug?
Hi guys, where do i find the coolant drain plug? found i was low on coolant yesterday so bleed the system and topped it up, but i figure it must have a leak somewhere so i've ordered a nice set of samco coolant hoses so will need to drain it to fit the new tubes, cheers Steve :thumbsup:
not sure on the mr2 but mine has a bung on the bottom of the rad, rhains will be the best one to ask i'm sure he'll be here soon :thumbsup:
depends if it's for the mark 1 or 2 Steve, there is a plug as Dawsey says on the front of the rad, bottom left i think
If its' an SW20 there are six drain points for the coolant system:
1 - Radiator bottom right (left looking from front of car).
2 - Radiator top left (mainly for bleeding air).
3 - Heater (under bonnet - centre & under windscreen - air bleed).
4 & 5 - One plug on each transfer pipe (under car & just forward of engine).
6 - Engine drain plug - above off-side drive shaft.
Use 1, 4, 5 & 6 for draining system (but not when its hot :o ).
Use 2 & 3 for bleeding system.
PM me if you need any more info on the SW20. :hokus-pokus:
PS: mark 1 or mark 2 - sounds like a Capri :censor: .
