Suspension Question
Zuban
Hi, does anyone know what the differences are between the superstrut suspension on the st205 and import st202's that have the superstrut fitted?.
Thanks :D
are there any ????
are there any ????
this is what i'm wondering, if there was any sure way of knowing i'd order up some st205 springs or coilovers but as i'm not sure its a lot of money wasted if there not!! :crybaby:
really need model and frame number to be sure , but this may help you decide.
its a 1998 st202 ss-3, i'm basically trying to figure out if i bought a set of coilovers for a st205 would they just bolt straight onto my st202, I know the spring and damper rates would be higher due to the st205 weight, but that would be fine as i'm going to be using it on track so would like it to be stiff. The front looks to be the same, but the rear struts look like they might be different, but would they still fit?
rear struts carry the same part number
really! thats pretty much all i needed to know thanks :thumbsup:
