Headlamps
Barry61
2001 Avensis. After having one cracked headlight and then the second one completely shattered I invested in some plastic protectors. They're easy to fit but you must emerse plastic clips in hot water, or getting them on the protectors can be a real pig. Oh and its a good idea to put the clear plastic in the sun or even in a greenhouse to warm up before fitting. if they are too cold they could crack when snapping them on.
