Alarm Problems Help Needed!
mk6phill
ok before i start,. i have searched the forums for anyrelated topics and have found a few with no good results for me,.. from searching i guess on our 94 GT it has a scorpion 5000 alarm.
The Problem,..
basically the alarm will not sound,...when locked by remote and unlocked by key the alarm does not go off, we have also tryed with someone being in the car while locked and moving around,..the motion sensors only flash when within a couple of mm's,...
it does sound when the panic button is pressed,.and we have searched for the contorll box under the gear leaver area and cant find one.
we have also tryed the little round key into the back of the alarm also with no results(can anyone point out where this should be set aswell either towards the engine bay or the floor :thumbsup: )
at this moment we are unsure about whats going on and would like some help asap
thanks B)
to put inshort can someone direct us to the controll box and or the alarm ecu,..so i can ajust the sensetivity settings and would this also affect as to why its not sounding when opened by key???
If it's got a Scorpian Alarm fitted it could be anywhere, you might need a good auto electrician to sort it out.
The Standard Toyota Alarm (TVSS) control box is under the gear lever but it sounds liek you've had the wipped out and a scorpian fitted???
IS your car UK or JAP, it looks UK from your rear number plate
its a uk car,.weve only had it a few weeks and havent had anything changed on it yet,.so all i know is the alarm is the scorpion,..i think am gonna end up pulling the dash out and just following the wires for the motion sensors
