my clutch slipps in high revs i take it will need replacing :unsure:
cheers ad :D
Yes it will better to get it done sooner than later as you might cause damage to the flywheel. I know for the turbo starlets you can get uprated sports clutches from starlet gt turbo . co . uk (remove the spaces :rolleyes: ) but you might have to check to see if they use the same diameter clutch.
Simon
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
