Lower Arm Bushes
groupagt4
hey of got a st185 gt4 A just wondering if the lower arm bushes on the rear are the same as those of non turbo celicas thanx
Doubt it. Different rear suspension set ups. The 182 has two tubular arms which are non adjustable. The 185 has one tubular (adjustable) and one pressed steel arm. The only bush which looks as though it may be the same is the front arm inner bush.
Hope this helps. :thumbsup:
supra ma70 part number is 42210-14010, quantity x 4 can be used to replace the spherical bearings in the no.1 & 2 rear control arms
the above image comes from: http://www.gtfours.co.uk/how_to/rear_bushes/rear_bushes.htm
Cost:
£24.97 + VAT less 10% discount from Toyota Salisbury.
£25 delivered from cheaptoyotaparts.co.uk
Fitted these parts recently:
hope that is of assistance.
regards
