Gen 5 Gt4 Turbo Set From Ebay
dojomaster0
looking at this turbo upgrade set up on eBay 8059734062 ,and wondering if anyone thinks it any good? ,and what i would need to do extra to the engine if i had one fitted, many thanks in advance. :thumbsup:
The seller also does that set up as a buy now for 600 quid. Not a bad deal i suppose. Don`t know about the quality of the turbo, actuator and wastegate, but i`ve got an XS pwer manifold and DP fitted. No complaints there. To get the best out of that turbo you`ll need to upgrade the injectors, fuel pump and something like an e-manage piggy back ecu. Then yu can start on the internals. Forged pistons. Steel HG. Uprated clutch.Then there`s the mapping to consider as well as sorting out a FMIC. The topmount is good for about 300BHP. So to answer your question. It`s probably ok but you will need to do a lot of supporting mods to get the best out of it. :yes:
as usual top quality advice from daktari , many thanks i will keep it in mind and sort out a proper performance garage for a price but guessing quite a bit. cheers :thumbsup:
