Colour
Andypr
:blink: Hi,can anyone tell me the paint code for Thunder Gray Met on the T Sport as i,ve got a small stone chip on me bonnet,i went to Halfords with a string of numbers but was told that the paint code is no longer on the vin plate on cars from the years 98 onwards.Is this true.How was Donny i was to go but sadly my grand in ireland took ill so had to go to see her,but with a bit of luck there a show at Elvrington York on the 21 May.before i forget has anyone whos got a BLITZ backbox on ther car found any corrision on the end tail pipe mine must be about 2 years old if that and at nearly £400 i'm ****** OFF.
How does that work Al.. does he just Copy n Paste it onto his bonnet? :lol:
Clever bugger! :bangin:
No, he turns his computer upside down and the paint comes out! ;)
lift up your bonnet and look at the silver plate on the bulk head, in the bottom left corner it will have a code. that is your paint code :thumbsup:
Order from toyota quoting the "PZ" number from the pic above.
Don't trust the mongs at Helfrauds or else you'll be painting it Mondeo Grey.
In fact, what's in the pic is what you want from your local Mr T. Not even worth bothering with Halfords.
It's what they call a "touch up set" as can be seen in the photo. I just asked them for "thunder grey" and it cost me £4.95 which is enough paint and laquer for a zillion stone chips! :thumbsup:
even worth buying because its a cheap item from toyota, now there's something u dont see every day
its stainless, so it wont be pitted, just needs some elbow greese :)
:unsure: Cheers earpl for that!But whats the best thing to get it back to it original gleeeming state and whys it happened?While i'm asking my cars making a funny noise ,when on full lock left or right it sounds like a swoossing sound from the wheels and when i turn tight for a corner its not catching anything,16" are on and not lowered.
:thumbsup: Cheers
:thumbsup: Cheers
Maybe a split CV boot, does it make a knocking/clunking noise?
:thumbsup: Cheers
:huh: The noise is like the pads against the disk,and comes when i turn on full lock or go round corners fast.Also the pitting on my Blitz some thing i can feel on the surface,is there any polish for metals i can use?
A swooshing sound is your Power Steering pump... when you put full lock on it's just the pump reaching the end at dispelling any excess pressure.
If it's when going round corners then it could be anything... most likely a suspension top-mount as they went on mine and that was when going around corners quickly (speed-bumps cause this!! :ffs: )
For your Blitz... it won't be pitted as it's stainless, it'll just have a bit of tarnish, tar and maybe a scratch... best way to deal with it is to give it a good wash and scrub with a decent brush, then use tar-removal stuff, then wash again using some elbow grease to clean it properly and finally use any metal polish, although I hear autoglyms is very good.
:D Cheers seveer unaek
