O/d Light Flashing
supra TT myster
Hi
On my supra TT automatic, i have noticed that when driving along with the O/D in, sometimes the O/D light on the dash flashes, and other times it stays off? What does this mean?
It hasnt been deristricted nor has it got a converter for MPH, the dial has the 110 one where it is spaced out to show MPH.
Is it a MKIV or MKIII?? inmaterial really either way you need to do a diagnostics check on the gearbox by the diagnostics box in the engine bay, just need to short out 2 pins but cant remember which ones, look at the tech tips on www.supras.co.uk
Check the connection to the O/D switch. if there is no connection the light flashes ;)
Hi
Where does the connection go to for me to check? Do you know?
