Immobilizer
ritey
what kind of Celica is it?
Gen 5? (popup lights)
Gen 6? (quad lights)
Gen 7? (new shape)
Also what model is it? GT, GTR, ST, SR, GT4
Also I'm guessing it's a UK car and not a Jap car??
Gen 7? (new shape)
quad lights gen 6 uk model 1995 st
OK is it the stock immobiliser?? Has it also got an alarm linked in with it?
Does the alarm go off or is that all ok? Does your remote keyfob open the doors? What does the Led indicator do behind the gear stick when you get in?
This thread has some info on the alarm system:
http://toyotaownersclub.com/forums/index.p...=50803&hl=alarm
You could try the trick which disables the security system - open the car with the key - alarm should sound for 30 seconds during this time turn the key to ACC, wait until alarm stops (30 seconds) then start the car.
Don't worry if the alarm doesn't sound but try the above anyway - it's got to be worth a shot.
Gen 7? (new shape)
any ideas ?
ok its worth a try be back to u shortly, fingers crossed,
Gen 7? (new shape)
any ideas ?
Gen 7? (new shape)
any ideas ?
factory fitted immobilizer and yes it is linked to alarm. when trying to start engine immobilizer kicks in and alarm goes off continuely ..... plz any help reply by e mail cos i dont know where the hell i am here and i am relaying this to a man, hence typical woman havent got a clue, e mail is janeyw20022002@hotmail.com thanx !!!!!
heyyyyyyyyyyyyyy cheers everybody for ur help we have success thanx alot !!!!!
No trouble,
Any chance you can post exactly what you did - just in case somebody comes along with the same problem in the future.
Cheers :thumbsup:
Gen 7? (new shape)
any ideas ?
that was short lived tried ........http://toyotaownersclub.com/forums/index.php?showtopic=50803&hl=alarm which worked took it for short run all ok turned engine off and tried starting it again but immobiliser kicked in and it wont start again :(
Gen 7? (new shape)
any ideas ?
anybody got any other ideas please !!!!!!!!!!!!!!!!!!!
had it running using ..............http://toyotaownersclub.com/forums/index.php?showtopic=50803&hl=alarm method took it for a short run stopped engine tried restarting but immobilizer kicked in again , help !!!!!!
OK, first of all stop pressing the quote and reply buttons!! Just use the Add Reply Button at the bottom!!
Try getting out of the car, locking the car with the key then starting again with the method above.
You still haven't told us exactly what you did to get it running. Did the alarm go off when you tried etc etc. Let us know the details so we can help you :thumbsup:
Did you try doing exactly the same procedure again though, it should work over and over again, but it won't get rid of the problem it's just a workaround.
You still haven't given us all the details
