I Want To Install Super Charger
ala HELG
Hello, i am from russia (so sorry for my bad english) , have a toyota yaris verso 1NZ.
recently i`ve buy a super sharger from 1G-GZE engine, and wont to install it.
What necessary to replace?
MAF sensor, nozzles, fuel pump? or this would not replace?
Broadly speaking, more simply to install a BLITZ supercharger, but difference for price didn`t allow me intall the BLITZ, because 1G-GZE supercharger price only 30$.
don't forget you'll need to have the ECU remapped unless it came with a piggyback ECU to controll the fueling, you'll probably need a stronger clutch as you'll wear yours out pretty fast with the extra power.
Uprated suspension
Upraded brake discs/pads
I wouldn't have thought the MAF would need replacing
Fuel pump may be OK as you won't be running to much power
Also standard injectors should work.
It depends on what power your looking at, some things may not need replacing
Kimi would be the best to ask as she had one fitted, i'm sure she would know what they replaced
