Hid/xenon Lights
szilu
You seem to know your stuff Corsol :thumbsup: !
I want to replace my bulbs as I dislike the appearance of the orange/yellow glow from the current bulbs, and they light up the road quite poorly IMHO. In my yaris I fitted some Philips Blue Visions bulbs and they were great but I'm having trouble getting some for the Corolla.
So I want the look of HID bulbs but I can't afford them done properly - so whats the best/next option?
Cheers :thumbsup: !
Cheers :thumbsup: !
Check:
http://www.lighting.philips.com/in_en/cons...ighting〈=en
http://www.osram.com/pdf/service_corner/Wh...ype_are_you.pdf
:thumbsup:
hi, the bulbs you see in the picutre are not just bulbs, they are connected to a ballast!.
go for japanese makes or german only not chinese.
I mean "bulbs" (with wires, balast, etc......) .......
If U want "fancy" car/lights, then allmost anything could be OK.....If you want real ( & LEGAL) performance then original parts are the answer.
yet toyota doesnt even have an hid part for the corolla?!
Cheers :thumbsup: !
Check:
:thumbsup:
do you have this type of bulb fitted in your car?!
any pics?
-If xenon lights is your TOP prioroty than U should look for another car... :D
-I have OSRAM light@day-low beam, high beam are OE,
-No pics
-If Xenon lights is your TOP prioroty than U should look for another car... :D
-No pics
Yes sir,
Philips are the best bulbs then ........ top work fella and cheers for all the info :thumbsup: !
jus completed a 8000k hid upgrade
you got any more pic's, looking nice
Hi corsol
Could you please tell me what are the standard lamps in E12 corollas, H1 or H7?
I understand that using the +50% H1 or H7 lamps has no risk at all. Do you know how much power they consume and how it compares to the standard ones?
my understanding is that the +30 and +50 lights are so called because they replace the halogen gas with xenon ( or another inert ) gas.
this allows the filament to burn hotter/brighter for the same input power, thus emmiting more visible light.
what this means is that the lights are 30% or 50% brighter than halogen counterparts at the same power.
because the legal limit is on the power of the bulb, you get more light for the maximum allowable power (55W dipped / 60W main for road use)
Osram and Philips are the best. Watch out for blue ones that are just normal bulbs painted, as the paint absorbs a lot of the emmitted light.
my hid takes 35w
Hi corsol
h7
