Interior Light
bhinderharminder
Hi guys,
ive bought a new neon interior/courtesy light for the inside of my E12 corolla, i have wired it all up correctly and chect it and it all looks fine. But when i open a door or turn on the light manually nothing happens. But if i connect the light directly to the cars Battery it works fine?
Dose anyone know what the problem could be? the light is rated at 12v.
Cheers
Hi guys,
ive bought a new neon interior/courtesy light for the inside of my E12 corolla, i have wired it all up correctly and chect it and it all looks fine. But when i open a door or turn on the light manually nothing happens. But if i connect the light directly to the cars battery it works fine?
Cheers
you may find that the interia lights run at 3 volts to save power if you leave the door open so it doest run the Battery down
Hi guys,
Cheers
so there is no way i can use the neon light then? or can i buy some knind if inverter?
mmm.. if you get a 3v relay it will work. wire the 3v relay up in parallel with the interior light, then use the +12v to do your neon
thanks for the reply, just had a look on maplins site, which one do i buy :wacko: ..lol
maplin site
cheers :thumbsup:
FJ42V should do it. its rated for 6 amps but your neon will pull naff all.
thanks for that, will let you know how i get on,
cheers
