Just changed the side (parking) bulbs and headlights.
Warning - the side light access on the Battery side f/n/s is really tight - in fact I had to get my wife to do it as my hand just wouldn't physically fit in the gap. Anyone else doing this - use a mirror to see what you are doing and allow plenty of time !
Warning - the side light access on the battery side f/n/s is really tight - in fact I had to get my wife to do it as my hand just wouldn't physically fit in the gap. Anyone else doing this - use a mirror to see what you are doing and allow plenty of time !
i changed them both on mine only took about 10min for the 4 of them (2 white driving bulbs and 2 philips blue sidelamp light bulbs) but i have dainty hands and fit well in the gap there is :rolleyes: ;) :yes:
piccies?
piccies?
of what? :unsure:
of the bulbs shining from your aygo. not for the main beem really just to see how the sidelights look. as the main lights look pretty much the same but white and brighter.
  • 2 years later...
I just had a quick look at the light access.
Looks like the side lights have a retaining clip that slides off first ? And then the bulb holder pulls out ?
Can someone confirm, and yes the passenger side one looks a real !Removed! to get you hands in there !!
The piece of metal you see holds the plug onto the fitting.
Removal of both positionlights (sidelightc?) and indicators
is just a matter of twisting, then pulling backwards.
It's all in the Owners Manual too...
Passenger side bulb access is easy if you just loosen the Battery bolt and slide the Battery over a bit :)
