I was having a rumage around underneath the steering culumn to see about wiring in a turbo timer, when I stumbled across a little electronic gizmo, with some LED's and an ariel. All the writing was in Japanese, so I made a note of the numbers on the side and Googled them.
It's only a flippin remote start module! :blink:
Does anyone else have this or know how to make it work?
And how do I wire up this timer, still haven't worked it out!
I would leave it. Remote starters are relatively cheap now and trying to activate a disused one may cause some serious headaches.
For starters you would need to know the frequency so you could find a remote sender.
They may use multiple signals :eek:
Get a new one fitted :thumbsup:
