:) Hi all, I am very impressed by the power output of my 3 litre hiace, I was wondering if anyone knows the output it is the EFIturbo diesel .Any info would be nice Thanks Phil
:rolleyes: Ok so its a mystery! If I do find out I will let you all know :thumbsup:
Checked Parkers?
Find another car the engine is in, and cross ref if it's not on there.
:) Thank you Ben i will give that a try
:) Spot on Ben it appears that the capacity is 2982cc power output is 161 bhp and here is the impressive bit the torque figure is 343nm or 253lb/ft! no wonder it pulls so well :D
Same engine in the LC colarado/prado/and later surfs.
The 3.0ltr Surf is only 130HP @ 3600rpm 289nm @ 2000rpm, so are you sure about those figures.
No problem .. I know imports are a bind to find any useful "english" information.
:) No not dead sure ,I took the numbers from a road test however 130 bhp seems low for a turbocharged 3 litre are your figures correct?
1995 hiace is.
Displacement, cc 2982
Engine model 1KZ-TE
Max.power (Net), kw(PS)/rpm 130 ps (95.62 kw) / 3600 rpm
Max.torque(Net), N*m(kg*m)/rpm 29.5 kg*m (289.30 N*m) / 2000 rpm
1995 surf is.
Engine model 1KZ-TE
:) Thanks that clears things up :thumbsup:
