Problems With Website
Steve
I had a blank screen this morning
It helps if you switch your computer ON ;) :lol:
Dont go there, my new computer does not even power up. I will have to get Naz to look at it.
The forum is a ok today
I'm still getting the same error, it says:
IPB WARNING [2] mysql_connect(): Access denied for user: '***************' (Using password: YES) (Line: 131 of /ips_kernel/class_db_mysql.php)
SQL error: Access denied for user: '*************' (Using password: YES)
SQL error code:
Date: Friday 12th of May 2006 10:17:03 PM
But it's probably just my computer
trying to think what time i did another modification as the first modification did not work.
are you getting this error still?
SQL error code:
No, last night I went on gold using the goldmember site & clicked "Back to Reality" & it loaded & now I've just tried the normal way & it worked so problem solved, good work :thumbsup:
This only seems to be on certain topics, but... am I going mad or is the view count not changing from 0 even though people have replied -so must have viewed???
Also bar at the bottom that tells you who is viewing a topic has dissapeared
To the two above posts ...... Kerby told me yesterday that TOC have taken off the features to try and reduce the cpu load or something
I'm sure somebody will let you know
But he said it will be back soon :thumbsup:
