Alternator Belt
fractured
This probably sounds like a dumb question, but how do I change the alternator belt on Celica GT with 3S-GE engine?
I already tried loosening the tensioner bolt, but I figured I must be doing something wrong because the tensioner won't budge.
Any help will be greatly appreciated! :)
i think there is also a bolt through the centre of the tensioner itself that needs loosening .Then you adjust the tension using the alternator adjusting threaded bar.
Thanks for the info! :)
I was actually thinking about that myself, but I ended up not trying to loosen it because I wasn't sure and didn't want to break anything.
