help i ve snaped 2 front studs can some one tell me how to replace them I can see how they fit but i can't get the break disc away to know them out - do i need an extractor to pull out the 4wd hub?
i could realy do with a diagram of the front drive shaft set up
hammer them out and hammer new ones in , they sits on a spline just like a drive shaft end.
cheers, but i cant get the 4wd hubb fully of to get at the studs
Remove the caliper and then the hub, then you need to undo 6 bolts to split the disk from hub, then they will hammer out.
have tryed that but i can't seem to get the chrome 4wd hub off it looks like the drive shaft is stopping it - ive got the blak and red locking switch off
i've been told theres a horesshoe clip(sirclip) to come off first but i can't see one, is this true?
this is starting to :censor: me off - a simple job made hard
You'll need to pull the whole hub off the spindle to get to the bolts that hold the disc on the hub from behind the disc.
i still cant get the chrome hub off i belted it and wacked it but still no movement.
iv'e been told that a sirclip hold the cogs inside it on to the drive shft and they come off first
IS THIS TRUE?
Could realy do with a diagram of the hub set up - it's a 97 hilux with manual locking hubs (it's a UK model)
tell me the chassis number and you will get a diagram of your exact motor .
give me a bell on the 18th - and i will have the chasis number for you
this is very much appriciated
why the 18th dont the car have a vin plate ??
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
