Brake Advice
Johndcfc
My rear brake disc's are about to die.
So rather than line Mr Toyota Dealer's pocket full of gold I was gonna get some of those decent looking brake discs from fensport.
So the question is - can I swap the oem brakes at the front (as they arnt that old) and use them at the back then get some decent fensport ones for the front?
Cheers
John
Cheers
John
I don't think so. The rears are a lot smaller, and solid disks. The fronts are vented. The rear disks aren't that expensive for the standard replacements.
Cheers
John
Cheers
John
NO will not fit totally diff!
black diamonds ones are a good choice, but you will have to wait for them as they have to make em so prob about a couple of weeks! do front and rear drilled ect look nice too
cheers
cheers
Thanks Guys, I think I'll get some standard rear discs - then get some decent front discs later.
First bit of money I've had to spend on the car after 9 months of ownership - certainly beats my old fiat punto!
black diamonds take about 3 days to arrive. well thats how long it took for me. I would suggest you get down down your local motor factors and buy some DELPHI discs and put some decent pads on. On the unloaded rear of the car that grooves and such like make less of a difference.
