Water Pump
Neil_turbo
Hi all
I'm just in the middle of putting the st205 charge cooler on my mr2 turbo, just a wuick question on the pump,
the two main outlets are water in and out, however there is a smaller one at the back, poss 4mm, what is this for?? some bleeding aid?
Cheers
Neil
oh yeah and progress here if anyone fancies a lok!
http://www.imoc.co.uk/forums/viewtopic.php?t=38669
If it`s a hole in the body with no pipe attached ithink you`ll find thats the tell tale hole to let you know the seal has gone inside. If it leaks it needs replacing. Not sure if the pumps rebuildable. :thumbsup:
cheers mate! had a few replies off other forums confirming that!
Cheers
Neil :D
