HI NOT SURE IF ANYONE CAN HELP,IVE GOT A 93 SSRX AND EVERYTIME I CHANGE FROM SOFT TO HARD SETTING ON THE SUSPENTION IT BLOWS THE SIDELIGHT/DASH LIGHT FUSE ANY IDEAS? CHEERS SI.
1st thing to check is do you have your caps lock on, next is are the shocks the original ones, if not it may be one of the wires hanging down and shorting out.
THANKS FOR GETTING BACK TO ME MATE,THE SHOCKS ARE THE ORIGINAL ONES.SORRY TO SOUND STUPID BUT WHAT DID YOU MEAN WHEN YOU SAID THE CAPS LOCK THANKS SI.
THIS WRITTING IS IN CAPS LOCKED AND IS DEEMED AS SHOUTING
This writting is with caps locked off and its deemed a normal speech
:thumbsup:
Dont change the suspension settings easy!
Have you checked for any shorts / damaged wiring etc, or that you are using the right rating fuses. Might be worth checking that your Battery and charging system are all working properly.
PMSL at the caps lock thingy :)
Have you checked for any shorts / damaged wiring etc, or that you are using the right rating fuses. Might be worth checking that your battery and charging system are all working properly.
Thanks for that mate will have a look.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
