Fitting Rear Strut Brace
armoredfist2002
I've received my rear strut brace after waiting 5 weeks, and need a bit of advice for fitting it,
can someone who has one please tell me do I need to remove just the one bolt to fit it or both of them, as the top bolt comes off fine, but the bottom one just spins around.
thanks
if its the rear upper strut brace that's fits in the boot, I dont think u have to remove both bolts. This will cause the shock absorber to pop up I guess. Dont try anything till some1 over the forum guides u better.
Regards and best of luck
Ismael
i've just removed the 1 bolt and fitted the brace above the other bolt, then tightened them back on, whilst holding the other bolt in place with a spanner, as not to let it spin round
