Knocking
IanGT
Got a slight knocking ontop of the superstrut knock when turning at low speeds, could it be balljoint needs doings or something else? :huh:
When you say on top, Do you mean the top of the shock absorber? Could be the top mounts are shot. :unsure:
Bearing? Loose wheel nut? Loose bolt in the suspension? CV?
I had a similar problem on a 1990 GT-R turned out to be the hub which needed replacing, I put new bearings in at the same time and that cured it.
