Fault With Yaris
Andypr
:help: Hi, any body know of a fault with the suspension bushes,as a mate of mine has a 1.0 and was told that they may pick it up at M.O.T time,as its all computerised the garage are given this info.
i had the bushes replaced at about 50k miles but they are classed as a wear and tear item. common problem to spot that they are on the way it is if you can hear a knocking when going over bumps
i damaged one when i crashed mine and im pretty sure its gone again... or another one has, as there is quite an annoying knock coming from the front end
its a pain as you cant locate it with the car stationairy! only does it when the bugger is moving :ffs:
yes thats right but they are fairly expensive to fit. cost me £120 for them to be supplied and fitted with drop links as well
Supply is about £21 a side IIRC, and it isnt too hard a job to do, probably end up snapping or cutting the link in the middle of the bushes too.
Only thing is that you have to order everything individually so;
2 Links
8 Bushes
8 Small Washers
2 Large Washers
4 Nuts
