Are the front Speakers coaxial or component Speakers? I'm assuming they are component Speakers if there are six in total, and if so, where would i put the crossover? Just wanted to check. Thanks! :thumbsup:
If your replacing the Speakers then it doesn't matter where to put the crossovers on the standard Speakers. Just install the new ones according to THEIR instructions. And I would wire in a new wire for the tweeter if you can't trace the original one (wouldn't know because I haven't tried).
Thanks for that! By the way, what are the actual sizes of the Speakers? I've read some say 10cm and others say 13.5cm. :huh:
they are 10cm. But easiest way to make sure is to measure them. The covers come off very easily using a small screwdriver then just pull them up. The back Speakers can be measured easy enough.
and how the heck do you remove the back Speakers?? i've already tried but i can't figure out how!!
