Tyre Pressure
teekay523
whats the psi range that i should be pumping my tyres up to cause these tyres are different to the normal 185 / 55/ r15 tyres. ???
Just use the same pressures as you had before.. there isn't much difference between the sizes... I run mine at 29psi all round.
I used to run my 195/45 R15 at 30psi all round! :thumbsup:
31 front 28 back - thats what my SR book says and they run 195/ 50 / R15
