Clutch, Pas, Chip
ballchrisball
Hi guys (and girls).
Firstly my main concern is my terrible clutch judder, or what appears to be a clutch judder, this only happens when my 1998 corolla 4a-fe is first driven in a morning and sometimes after work, and it only happens once then it is fine, but when it does happen it is really really bad. She has done 80,000mls and i believe she's never had a clutch!! If you people do believe this is a clutch replacement does anybody have any recommendations for a replacement??
Now my second problem, when cruising at relatively high speed 60-80+ in a straight line if i move the steering wheel from side to side is feels quite notchy/lumpy, i have checked the PAS fluid level and all is o.k. Any ideas?? All advice welcome!
And my 3rd query is these resistor type chips you find on e-bay, has anybody tried these or anything similar?? or does anybody have any advice on cheap power gains, if at all possible. i currently have a cold air induction kit and that's it. Again all advice much welcomed..
THANKS :help::help::help:
I can only answer question number 3 im affraid - Linky
If you already have a induction kit the next thing I would go for would be an exhaust. This will help the breathing of the system and would go perfectly with the induction kit and will propably give around 1-4 BHP in total :thumbsup:
It will also give you a nice sound ;) !
