-You can not hit hi-cam (Lift) when your engine coolant temp is under 60 degrees celsius.
-When your pertrol light comes on you cannot hit hi-cam (lift)
Correct me if im wrong..
I don't know the exact temperature but it's right that you can't get onto the hi-cam when engine is "cold". In addition the limiter is at 7000rpm.
no lift when the petrol light is on??
that would be a b :censor: tard when you needed it.. :ffs:
No mine hits the lift when the fuel light is on
But it only revs to 7000 when cold
incorrect !
I've tested it today , works fine :D
I only get to 7000 rpm when my motor is cold .. :!Removed!:
but i have the lift when the petrol light shines like a christmas light .. :wacko:
My bad,
The CTS can hit lift when the fuel light is on. Thanks for the correction!
