Corolla Stands
khizman
where are you meant to put the jack stands on a toyota corolla?
the manual isnt very useful :(
its a 2002 d4d (new shape)
The indicated jacking points for most vehicles are specifically for the jack supplied with the car. These are meant for road-side use only in the event of a flat tyre.
The jacking points are invariably positioned where (if used) there will be some minor cosmetic damage to the paint work. Avoid using them if possible
A trolley jack is the safer option (in conjuction with axle stands). A full kit is about £20 - money well spent.
Most Toyotas have a rear cup jacking point usually in the centre of the cross-member in line with the rear wheels. In the front, directly under the engine will be an engine support running from the front to the vehicle to a point roughly under the dashboard. You can safely jack a car (using a trolley jack) from here.
If you look at the sill under the car it should have 2 indents at the front and 2 at the rear. The jack sits in them to provent it slipping.
