Torque Setting
GT4 EIRE
HI,I AM LOOKING FOR ALITTLE HELP FROM YOU GUYS.I HAVE JUST BOUGHT A CELICA GT4 ST185 WIDE BODY (JAP IMPORT).I"M LOOKING FOR THE TORQUE SETTING ON THE DRIVESHAFT NUT,30 MM NUT I THINK.ALSO I WAS ADVISED TO PUT NGK Iridium SPARK PLUGS IN HER BUT I FIND HER TO SPLUTTER A BIT AND STALL AT TIMES.THE CAR SOMETIMES DECIDES TO GO FROM IDLE AT 800 AND THEN SHOOTS AND HOLDS AT 2000rpm FOR 15 TO 20 SECONDS EVEN WHEN COMING DOWN OFF TURBO TIMER.ANY IDEAS?I WOULD APPRECIATE ANY HELP YOU CAN GIVE ME. THANKS PAT
Can`t help with the poor running i`m afraid but the Front hub nut shouldbe torqued to 186 Nm. :thumbsup:
Do not on any acount overtighten them as this will lead to driveshaft failure. :eek:
THANKS FOR REPLY,DIDNT GET BACK TO U AS COMPUTER WENT DOWN FOR THE LAST TWO WEEKS.
