If this helps anyone.....
I've Been looking for some accessory switches for my rav for some time..... anyway I have finally found these: -
The one on the left is just the switch without the front fitted and picture 2 is with the switches in the on position.
They are from RS, part number 841-817 SPDT with a red LED, but you do need to trim about 1mm of the sides of the existing holes mind.
They do look very good....but ,did you know that the Toyota range of vehicle switches share the same size dash hole, so any switch from the early 80's to date would have fitted in the hole. :thumbsup:
