Free Gen 5 Bonnet
TCGT
Hi
FREE to good home if you can collect.
Gen 5 bonnet from a 90 import, finished in glossy black.
Taken off my car to make way for a GT 4 bonnet.
Just minus the front plastic trim and washer jets, complete with soundproofing.
I am in Stockton on Tees in the North East.
thanks
Whoa, dont go any where, I work in Stockton/Elton and have a gen 5 balck celica and its always good to have a spare bonnet, send me a pm or an email, if it hasent already gone to the evil tip.
Ash.x
Yay KITT has 2 bonnets :blink::thumbsup:
It was very nice to meet you John, Hope we can work on our cars together sometime :thumbsup: Your Celi is a stunner in the making. :)
Let me know when you have that Haynes manual handy and I will pop round and pick it up. :thumbsup:
Hugs Ash.x
hi Ash,
I'll get the manual home and let you know when to pick it up.
Wish I knew a bit more about my particular Celica as there are one ot two things that puzzle me, The big front wings and the 7 inch wheels with plenty room still under the arches etc.
Was nice to meet you too, members seem to be thin on the ground around here.
cheers
What you have there John is a bit of a rarity.
Official name Celica 2.0 GTi Liftback Wide Body
Generation 5
Model Code ST182 WB
Chassis Code ST182L-BLMVFG
release date 1990
final date 1994
Comments Limited edition with ST185 side panels, otherwise the same as a regular ST182.
Engine
Code 3S-GE
Aspiration natural
Cylinders 4
Valves/Cylinder 4
Valves 16
displacement 1998cm<sup>3</sup>
Bore 86.0mm
Stroke 86.0mm
Bore/Stroke Ratio 1.000
Compression ratio 10.0:1
Power output 115kW@6600rpm (154bhp)
Torque output 186Nm@4800rpm (137lb/ft)
Power over displacement 57.558kW/1000cm<sup>3</sup> (77.186bhp/l)
Torque over displacement 93.093Nm/1000cm<sup>3</sup> (68.662lb/ft/l)
Fuel Unleaded
Alternator 840W DC, max current 70A
Battery 12V 48Ah
Head material alloy
Block material cast iron
Ignition electronic
Injection electronic
Cooling injected liquid
Cams two overhead
Cam drive belt
Drivetrain
Transmission 5 speed manual
gear ratios 1: 3.285:1;
2: 2.041:1;
3: 1.322:1;
4: 1.028:1;
5: 0.820:1;
R: 4.058:1.
Final drive 4.058:1
Performance
0-100kmph (62mph) 8.7s
Top speed 220kmph (137mph, 367454furlong/fortnight)
Power per Tonne 92.817kW (124.469bhp)
Weight per Power 10.774kg/kW (8.034kg/bhp)
Fuel Economy
Motorway 5.8l/100km (48.7mpg (UK), 40.6mpg (US), 817574rods/hogshead)
City 9.9l/100km (28.5mpg (UK), 23.8mpg (US), 478982rods/hogshead)
Overall 7.8l/100km (36.2mpg (UK), 30.2mpg (US), 607939rods/hogshead)
Measurements
Length 4.420m (14' 6.0")
Width 1.705m (5' 7.1")
Height 1.305m (4' 3.4")
Wheel Base 2.525m (8' 3.4")
track width Front: 1.465m
Rear: 1.430m
mass 1239kg
fuel capacity 60l
oil capacity 4.2l
coolant capacity 6.5l
Drag coefficient 0.31
Steering Wheel Rotations 2.7
Brakes
Brake System Features powered brakes
Front ventilated discs
Rear discs
Suspension
Mount Front: independent, McPherson
Rear: independent
Shock absorbers telescopic gasfilled
Stabilisers front and rear
Tyres
Rim size 6JJx14
Tyre size 205/60R14
Hi Dak,
Is this info based on the VIN number or the model code as it slightly differs mine being
E-ST182 BLMVF
and your quoted one
ST182L-BLMVFG
cheers
hi Dak,
thanks for the info, I hope it is a little different , it certainly looks differrent, as it makes it all the more worthwhile getting it back on the road.
I have traced this if it interests anybody, and isn't common knowledge.
E = years pollution code
S = S series engine 3sge
T = platform Celica 86 on
182 = 3sfe or 3sge engine
(L or R) optional left or right drive
B = Celica
L = liftback
M = 5 speed Manual
V = trim level Luxury sports
F = twin cam(high performance)
if final code is missing G etc then probably Japanese car, which explains why it is not present on mine.
The reason I asked you for the vin number was because I knew our Dak would come through and tell you what you had.............I have no idea when it comes to numbers and such on the Celica's.
John's Celi looks big and mean hence the wide body so the GT4 bonnet looks just right.
Needs to be chucking a Turbo lump in there next. That`d be awesome. a 2WD tubbied Celica. Guess it`d be a GT2. :D
