I've Lost The Horn!
funkyg
My poxy car!!!!
Realised this weekend that my horn has stopped working. A couple of weeks ago the air bag light came on, last week the steering wheel controls for the stereo stopped working, and now the horn doesn't work.
Given that I don't use my horn a lot (I'm not very horny!) it is probably the case that all these problems are related to the cabling in the steering wheel/column.
I checked the fuse for the horn, and it hasn't blown. There is also a relay for the horn, but I don't know if there is a way of testing that.
How easy is it to get to the wiring to the steering wheel to check connections? I'm guessing I should do it with the Battery disconnected (don't want tthe air bag going off in my face!)
Cheers.
Mike.
Given that your problems all relate to circuitry on the steering wheel itself I would imagine that the boss contacts between the wheel and the steering column are fouled in some way. I had a similar problem with my old VW Beetle. (granted it didn't have an air bag or stereo but the principle is the same) Removing the steering wheel will probably reveal all. I think that you'll need a set of allen keys to undo the air-bag etc. from the back of the steering wheel.
