Hello everybody. I just purchases a new 2003 camary Le V4. I noticed that when the a/c is on and I go to slow down, right before the car stops it feels rough (like its going to stale-but it doesn't).When the a/c is not on, this doesnot happen. Is the car's idle speed to low? What can be wrong?
sounds like the idle up valve isn't working take it back to the dealer and make sure they fix it
Thank's for your reply. I have one more question. When I start the car and turn the A/C on the rpm dial doesn't move at all. Is this normal? At idle it just stays at about 800-1000rpm even with the A/C on.
that could be the i/up valve it may need opening a bit. rpm shouldn't rise much but you should notice
