T Sport Alloys
Ed_Shek
Does anyone know if it is possible to fit 17inch Wheels off a Peugeot 206 onto the Corolla T Sport. Both are four stud.
Cheers
Ed
Cheers
Ed
You will need to check the PCD of Peugeot (possibly 4 x 100), then the offset and c/bore.
C.Bore you can get spiggot rings to take the load, but if the offset is wrong, then forget it.
HTH
Cheers
Ed
HTH
The spec of the alloys of the 206 are:
4 stud x 108pcd x 7.5Jx ET25 x17
Anymore help on this anyone?
Cheers
Ed
HTH
Cant find anything definate, however think the PCD is wrong, i.e the studs are spaced out too much.
HTH
No they won't fit you.
You want a 4x100 PCD, not a 4x108 like on Peugeots, Citroens and Fords.
