Side Repeater Removal?
R6TH M
How easy are the side repeators to get off on the yaris? Mine seem to have some gunky green stuff growing round the edge, tis not very pleasant!! Any hints/tips would be appreciated
Ruth :)
Very easy...
Slide it to the left (or right) and pop it out from the corner. May take a bit of force, but it come's out eventually. It should tell you in your hand-book too as it's a bulb that may need replacing. You can always use a terry-cloth or microfiber cloth and sneak it behind it and rub until it goes! :lol::thumbsup:
if you are going to replace or remove the side repeater.
make sure you secure the cable that you've just unclipped from the side repeater, as it has a tendency to fall in to the wing.
it's a bit tricky to get out if that happens!
I changed both my side repeaters a couple of months ago, they cost me £39.00-ish from Toyota.
cheers for the advice!! i would hope they wouldnt need replacing as the car is only a year old :(
damn phase 2 eh ruth :P be carefull when removing them as i broke both of mine :P and now have wobbley repeaters :P
Yeh I got mine off only to work out that the whole they fitted into is **** huge!!! - and every side repeater I tried on my car to replace them doest fit! :crybaby:
so if anyone knows of any that do fit - please let me know!!! :D
I've got two from my yaris, there not new but they work. have them if you want!!
if you want new ones pop to toyota, £37.50 or something.
What happened to traditional flowers eh!? I don't know if it's gunna work trying to woo her with side repeaters!!! :lol:
Lenry....where in cowley are you? I'm in Littlemore
I find little flashing lights work slightly better, C'mon anyone can buy flowers, :P
