Hi all. Where can i find a knock sensor for my rev 1 turbo?
Without having me pants pulled down. and any ideas how much and where they are located on the block?
Are they easy to change?
thanks in advance. :thumbsup:
Guest rev3turbo
try IMOC or eBay for the knock it is common thing a lot of folk upgrade and use a GM one apparently it is a lot better,
it is located in the engine block just below the inlet manifold iirc
failing that i have one sat here.
mo.
try IMOC or ebay for the knock it is common thing a lot of folk upgrade and use a GM one apparently it is a lot better,
mo.
Cheers mate but i bit the bullet and bought a spanking new one. cost 111 quid :( . should've been more the bloke at toyota lost me the vat. :D just need to fit it.
  • 2 months later...
mo.
Hello mate have you still got knock sensor you want to sell it??
