Help!
ldjohnst
I have just had the CV joint changed on my celica and now the 4WS light is coming on. If I turn off the ignition it goes off and all works fine for about 5 mins. When the light comes on the rear wheels turn the wrong way for low speed. It was all working fine before the CV joint was changed.
Any ideas?
Any ideas?
i would check that there is no damage to the sensor when the cv joint was removed and make sure the new joint has a relucter wheel on for the sensor to pick up on .may have the wrong joint fitted so cant register the rotation at that wheel. :thumbsup:
