Power Steering Problems.
yellowchinaman
Hi All
After a lot of asking around, I've come to the conclusion that my Power steering is the cause of my steering wheel pulling to the left. I've had the wheels aligned and checked the breaking balance and they're all good. Does anyone know how I can fix this problem or must I take it to the mechanics?
If you are happy that the problems is with the power stering it is the rack that you want to be changing. The question is can you change the steering rack yourself. A replacement is much better that trying to repair one.
Sometimes you can get a recon unit but if I could I would be trying for a second hand original part. If you have the money a manufacturers recon or totally new rack would be the berries. :thumbsup:
have you tried swapping you front wheel to the back an vice versa quite often can be due to tyre wear its an easy thing to try before replacing steering rack :thumbsup:
Well my tires are all new and I'm pretty sure it's nothing to do with my wheels.
This rack you're talking about Martin. Do you have a photo or diagram of it?
You dont wanna have to do the rack if you can get away with it :!Removed!:
They aint cheap!!! :(
Not got any pics sorry...
As said if your happy it is the rack try here
Clicky
If you pm me your e-mail I will send you a pick I managed to get of the rack gear, cant access my web account at the mo to upload a pic and too lazy to sort it
