Indicator
ozzy666
lo all,got a small problem.my drivers side front indicator aint blinking,the side and back are but there short and faster than usuall.it can't be the bulb iv just put new ones in when i changed to clear repeaters bout 2 month ago.its the same side i'v had problems with when using the alarm.when i turn the alarm on or off sometimes the light would stay on and i'd have to keep turning it on and off till it was ok.i reckon its a dodgy wire or something like that but don't know where to look.and why are the other lights on the same side blinking faster than they should?? thanks for any help on this :thumbsup:
indicators blink faster to let you know a bulb is out. i'd check that bulb and its wiring before anything else.
hi do you know what would cause the hazards to stop working but indicators are working ???
Have you checked the engine bay fuse as this runs the hazards alone?
Fuse box Engine Bay 1 Legend:
F1 Starter motor
F2 Hazard lamps
F3 Horns
F4 Bridge link to F5, F6 & F7
F5 Audio system
F6 ABS control module
F7 Interior lamps, load area lamp, clock
F8 Headlamp - left
F9 Headlamp - right
F10 Spare
F11 Spare
F12 Engine coolant blower motor
F13 Air conditioning condenser blower motor
F14 Air conditioning system
F15 Main circuits supply
F16 Main circuits supply
F17 ABS
F18 Alternator charging system
F19 Airbag
F20 Injection system
1 Engine coolant blower motor relay I
2 Air conditioning condenser blower motor relay
3 Horn relay
4 Headlamp relay
5 Starter motor relay
6 Engine control module relay
Hope this helps and you get it sorted :thumbsup:
:thumbsup: thanx mate will try that!
F1 Starter motor
F2 Hazard lamps
F3 Horns
F5 Audio system
F8 Headlamp - left
F9 Headlamp - right
F10 Spare
F11 Spare
F17 ABS
F19 Airbag
3 Horn relay
4 Headlamp relay
