Tns 200 Error
funkyg
OK, latest problem with my Avensis, the Sat nav has stopped working!
I had to disconnect the bettery a week or so ago, and since recconecting it the sat nav doesn't work. The message on the stereo says "open door and check cd".
I do this, it spits the disc out which is clean, I then put it back in and close the door. It will then say checking CD for a bit and then go back to the original message.
If I take the CD out it does recognise that it is out and when I put it back in you can here the disc spinning up.
Anyone got any ideas?
Cheers.
Mike.
Cheers.
Mike.
Try take out CD, disconnect Battery (or sat from Battery at least), leave for a few mins, re-connect, put in CD...
Try take out CD, disconnect battery (or sat from battery at least), leave for a few mins, re-connect, put in CD...
Thanks for that. Tried it but it didn't work. Anyone else got any more ideas?
Thanks.
Mike.
Thanks.
Mike.
Hi I had similar probs so I made a copy of the disc using Alcohol 120%, which you can use free for a limited period, and the copy worked fine, :unsure: not sure what law in your country is as regards using a back-up of a disc you own?
