My 92 GTT just failed it's MOT because no ABS light came up when the car is started. Can someone confirm that it should? I've never noticed and have a sneaky suspicion that what the tester was looking for could be found if he pressed the 'scroll' button on the dash.
Please enlighten me. If the ABS light should come up and isn't what should my next steps be?
Thanks in advance!
i'd speak to a toyota dealer about it.
afaik the mot tester checks to see if the bulb lights up only . if the abs is working ok it shouldnt be a problem.
  • 4 months later...
Are you sure that the car has ABS? It was an option on the GTT.
Although having a "scroll" button implies that you have the dot matrix dash, which would make your car a GTT-L. :thumbsup:
