Removing Radiator Grille
Perfection
Anyone know how to remove the dariator grille? I have got a feeling the is some small clps on the side. DO I just push this grille toward the radiator to remove?
If you mean the lower one yeah it just springs into clips top and bottom edges.
The upper one is held in with 2 or three 10mm encapsulated nuts
I sprayed mine "lower grill"
The way I took it off, was to put my arm down behined it through the engine bay "with the bonet open"
if you get what I mean
