Gearchange Linkage
is the gearchange linkage a serviceable part on a sw20 , it feels a bit sloppy and i'd like to make it feel tight again.
i can also really hear the rod sliding through the car is this normal - thanks
ahh !! i see its cables , same as the celica with rubber bushes with a brass inner.
soon to be replaced with bearings
thanks anyways
Posted (edited)
as it got a long gear stick?
if so get one from a rev 3 it's shorter and helps no end :thumbsup:
only 4 bolts & your cables takes all of about 10 mins to change :yes:
You can get one from eBay Lookie
Edited by Roytoner
