If possible could someone please email me a translation to english , for the fuse boxes in car & under bonnet, as i'm trying to locate the relay that powers the rear tail lights & the location of the bulb failure unit..
I removed the rear left lens , taken out the stop/tail bulb cluster, removed the the 2 filiment bulb and was using a probe to find out what was what in order to fit towing electrics, i must have touched something wrong because the rear L&R tailights no-longer work everything else is fine...
I checked all the fuses i could see in the fuse box in the passenger foot well and in the fuse box under the bonnet above the Battery all the fuses are fine, both bulbs are fine so that can only leave a fuse that i haven't found yet , a relay or the bulb failure unit ....
Could someone help me please as i'm surpossed to be towing this coming weekend.
Desperate Daz (very) muzikwizard@hotmail.com
