Auto Transmission Fluid Change
gippo
Anyone know exactly whats involved in completely changing the trans fluid on my 1.6 VVTi GLS?
Is it as simple as removing the sump plug... or does the torque converter require flushing too?
Can you just tip the new fluid in....or will it need purging etc???
Is there a filter that would need replacing??
Any info would be greatly appreciated.......
Gip
raise the vehicle
remove filler plug and drain plug and drain the fluid
reinstall drain plug
add new fluid up to lower edge of filler hole
